Parallella Community • View topic - New Parallella SDK release! (Beta testers needed)
Re: New Parallella SDK release! (Beta testers needed)
Postby olajep » Thu Nov 13, 2014 12:28 am
Postby AndyC » Thu Nov 13, 2014 7:56 am
HI,
Thanks for testing it out.
I'm missing build-essential, I will give it a go....
Cheers
Andy
AndyC
Postby AndyC » Thu Nov 13, 2014 9:03 am
Hi Again,
Still the same problem, the script "build-epiphany-sdk.sh" is using "./download-toolchain.sh" but we are one level above if we are running outside the sdk directory:
andrewcapon@UbuntuParallella:~$ mkdir ParallellaSDK
andrewcapon@UbuntuParallella:~$ pwd
/home/andrewcapon
andrewcapon@UbuntuParallella:~$ export EPIPHANY_BUILD_HOME=/home/andrewcapon/ParallellaSDK
andrewcapon@UbuntuParallella:~$ cd $EPIPHANY_BUILD_HOME
andrewcapon@UbuntuParallella:~/ParallellaSDK$ pwd
andrewcapon@UbuntuParallella:~/ParallellaSDK$ mkdir buildroot && cd buildroot
andrewcapon@UbuntuParallella:~/ParallellaSDK/buildroot$ git clone --branch 2014.11 https://github.com/adapteva/epiphany-sdk.git sdk
Cloning into 'sdk'...
remote: Counting objects: 820, done.
remote: Total 820 (delta 0), reused 0 (delta 0)
Receiving objects: 100% (820/820), 10.66 MiB | 2.04 MiB/s, done.
Resolving deltas: 100% (418/418), done.
Checking connectivity... done.
andrewcapon@UbuntuParallella:~/ParallellaSDK/buildroot$ ./sdk/build-epiphany-sdk.sh -C -R -a armv7l -c arm-linux-gnueabihf
************ Epiphany SDK Build ************
Environment settings:
EPIPHANY_HOME=/home/andrewcapon/ParallellaSDK/esdk.2014.11
ESDK=/home/andrewcapon/ParallellaSDK/esdk.2014.11
Build settings:
Target architecture: armv7l
Build version: 2014.11
Build from branch or tag: esdk-2014.11
Creating the eSDK directory tree...
./sdk/build-epiphany-sdk.sh: line 223: ./download-toolchain.sh: No such file or directory
Aborting...
AndyC
Postby AndyC » Thu Nov 13, 2014 9:10 am
Ok, I have the problem.
If EPIPHANY_BUILD_HOME (incorrectly by the look of it, sorry!) is set before running the script it fails.
With it unset the build seems to be progressing.....
AndyC
Postby AndyC » Thu Nov 13, 2014 10:57 am
Thanks Olajep,
all built now.
Another question how do you monitor temps with the new kernel, /sys/bus/iio/devices/iio:device0/in_temp0_raw seems to be missing?
AndyC
Postby AndyC » Thu Nov 13, 2014 11:13 am
Another one:
e-gnu.armv7l.software-caching is missing from the image http://downloads.parallella.org/ubuntu/ ... 110.img.gz
Is it meant to be available for testing as this is one of the main things I am interested in?
AndyC
Postby olajep » Thu Nov 13, 2014 2:34 pm
Postby AndyC » Thu Nov 13, 2014 3:21 pm
AndyC
Postby olajep » Thu Nov 13, 2014 3:35 pm
Postby AndyC » Thu Nov 13, 2014 6:35 pm
Thanks.
I will just post this incase it has been missed along the way:
How do you monitor temps with the new kernel, /sys/bus/iio/devices/iio:device0/in_temp0_raw seems to be missing?
AndyC
