Parallella Community • View topic - Ideas for daughter cards?
Re: Ideas for daughter cards?
Postby anlumo » Fri Feb 15, 2013 5:15 pm
anlumo
Postby Folknology » Fri Feb 15, 2013 5:42 pm
That's a good idea @anlumo I think I will knock up a protoboard to test the template I am building, it will be a nice quick win..
regards
Al
Folknology
Postby Sundance » Fri Feb 15, 2013 7:48 pm
Flemming Christensen
Mobile: +44 7 850 911 417;
Skype: Flemming_Sundance
Company Home Page:
Sundance
Postby tschaboo » Sat Feb 16, 2013 10:01 am
tschaboo
Postby LamsonNguyen » Mon Feb 18, 2013 3:18 am
I was under the impression that Parallella would be released first, then work on daughter cards afterwards. I think becoming 'Something for Everything' is not necessarily a bad thing. Even if someone's grandma buys a board and only uses it for surfing the web, that is still spreading the word. ;)
LamsonNguyen
Postby 9600 » Mon Feb 18, 2013 12:12 pm
Postby theover » Mon Feb 18, 2013 5:33 pm
Postby Izikiel » Mon Feb 18, 2013 8:16 pm
I've been thinking in building a notebook with a couple of parallelas inside :P
It could be quite powerful and consume very little.
Thoughts on this?
Izikiel
Postby SamJBarney » Wed Mar 06, 2013 4:42 pm
SamJBarney
Postby Marko » Thu Mar 07, 2013 6:22 pm
I am new here, not among the original supporters, but signed up later for a second run card.
My interest is mainly in SDR, mostly for playing with radio astronomy interferometry.
There, the requirements are a bit different than the usual SDR stuff. What is needed is a higher sample rate with less precision, 8 bits are plenty. More channels are desirable, too.
So maybe a card with eight fast 8bit converters, with the option to assign the PEC bandwidth to either one, two, four or all eight channels. With 1GB/s PEC BW, this would mean 1x 8bits @ 1GHz, 2x 8 bits @ 500MHz, etc.
Would be also useful for making an oscilloscope.
The channels should have simultaneous sampling, and it would be nice if the hardware would allow timestamps to be inserted into the data stream, for example derived from an external 1pps signal.
Marko Cebokli
Marko
