Parallella Community • View topic - Build confusion. e-loader lib confusion
Postby AndyC » Sun Aug 10, 2014 3:00 pm
Hi Guys,
I have built the latest 5.13.09.10 sdk on a linux box for cross compiling.
The installed version on the parallella is also 5.13.09.10.
Now the linux box sdk used the e-loader.lib for building, while the contents of this lib seem to be in e-hal on the parallella board.
So when I cross compile and run on the parallella the e-loader.so is missing.
why are the two different? Do I have to build the sdk on the parallella board as well to get it the same?
thanks for any help
Andy
AndyC
Re: Build confusion. e-loader lib confusion
Postby AndyC » Sun Aug 10, 2014 4:19 pm
Ok rebuilt esdk on the Paralella and switched esdks to new one with the symbolic link in /opt/adapteva.
Now I'm getting:
linaro-nano:/opt/adapteva> e-reset
e-reset.e: ee_write_esys(): /dev/epiphany file open failure.
e-reset.e: e_open(): /dev/epiphany file open failure.
e-reset.e: e_reset_system(): e_open() failure.
I'm really beginning to loose the will to live with this board!
Is the only support route through this forum?
AndyC
Postby bcxcube » Mon Aug 11, 2014 3:29 pm
Andy,
If you are building the SDK from git you will need to use a Linux kernel which contains the Epiphany device driver. You can build a kernel which includes the Epiphany driver from the bcxcube_epiphany_driver branch of the parallella-linux-adi repository (https://github.com/parallella/parallella-linux-adi.git). Also, you'll need to either manually change the permissions on the /dev/epiphany device node or create a file named /etc/udev/rules.d/90-epiphany-device.rules which contains the following:
[bcxcube@parallella-bsc ~]$ cat /etc/udev/rules.d/90-epiphany-device.rules
##/etc/udev/rules.d/90-epiphany-device.rules
# Set appropriate permissions on the epiphany device node
KERNEL=="epiphany", MODE="0666"
Using a udev rule to set the device node permissions is recommended so that the permissions will be set automatically when the parallella boots.
Ben
bcxcube
Postby AndyC » Mon Aug 11, 2014 3:45 pm
Hi Ben,
Thanks for the info.
I had just about given up all hope, I will build the kernel and give that a try.
Many thanks
Andy
AndyC
Postby AndyC » Tue Aug 12, 2014 1:55 pm
Hi Ben,
I just want to say thanks.
I built the bcxcube_epiphany_driver branch and installed it.
Now I can cross compile correctly from my linux box, very happy camper now :)
Cheers
Andy
AndyC
Postby 9600 » Tue Aug 12, 2014 3:06 pm
Users browsing this forum: No registered users and 61 guests
