Hi list, I just received my A101020 board this weekend, I have it up and running the HDMI image.
The board is very cool, but I have a few issues.
The HDMI flickers. I tried setting it to 720p - then it suffers from some nasty red and green noise.
I have read that the Analog Devices HDMI IP takes up a lot of space, and I am interested in exploring completely custom display engines, perhaps starting very minimal out with something like the following and building it up (to a modern take of retro video hardware).
http://www.fpga4fun.com/HDMI.html
(In retrospect - I see now that I am pretty much stuck with the AD HDMI Encoder - so for the minimal case I will just generate a minimal logic simple test pattern - using the encoder)
Now the tricky part!
The lack of board specific documentation is leaving me a little confused.
Can we get some more detailed info on the A101020 boards (and I guess other 1.1 boards)
I am trying to get a fairly minimal system up with Vivado.
(Just Ethernet and a UART with the minimal programmable logic required to boot Linux would be fine) .
I am guessing no actual programmable logic is strictly necessary, though I am not 100% sure.
It is hard to verify exact the exact IO information required to feed vivado 2014.2's Zynq7 Block customizer without feeling
like I am going to fry something.
I have looked at the following links and ported what I could.
http://www.adapteva.com/white-papers/pa ... ce-design/
http://www.zedboard.org/zh-hant/node/1454
https://github.com/parallella/parallell ... x0_loc.ucf
Is there an itemised summary of what is different between a zedboard and a 1.1 board?
Perhaps the community could help to enumerate that information here in this thread!
Again, I'm not looking for a completed guide - just basic configuration data.
(Like the following fields in the Vivado block customizer)
Zynq Block Design
PS-PL Configuration
Peripheral I/O pins
MIO Configuration
Clock Configuration
DDR Configuration (does a a101020 board really have a mt41k256m32? I cant tell by reading the top of the chip!)
SMC Timing
Interrupts
If anyone has a half done vivado project I'd even be interested in looking at that...
PS - I prefer Vivado because ISE is not stable enough on my Ubuntu 14.04 VM (PlanAhead always crashes),
and the UI seems nicer.
mtm
