Vivido project for parallella
PostPosted: Fri Aug 12, 2016 9:26 am
by jimmystone
Hi, All
I find there is only one vivado project for parallella in
https://www.parallella.org/2015/03/23/new-parallella-elink-fpga-design-project-now-available-in-vivado/
However, most design of this project is make with IPs, and cannot be changed by its verilog code.
And I notice the source code of elink is move to
https://github.com/parallella/oh
Is there any vivado project works with these oh source code?
Or I need build one on my own?
Thanks.
Re: Vivido project for parallella
PostPosted: Fri Aug 12, 2016 5:49 pm
by peteasa
oh is the one! If you follow the build instructions then it will create a vivado project and an fpga with the latest elink.. good luck!
Peter
PostPosted: Sat Aug 13, 2016 12:41 pm
by jimmystone
peteasa wrote:oh is the one! If you follow the build instructions then it will create a vivado project and an fpga with the latest elink.. good luck!
Peter
Thanks, I am using oh with vivado 2016.2, now. But I found system_bd.tcl in oh/src/parallella/fpga is generate with 2015.2.
Do I need to install vivado 2015.2 for it? Or there is some way to upgrade it to 2016.2
Please help, Thanks.
PostPosted: Sun Aug 14, 2016 5:42 pm
by peteasa
I have found that xilinx modify the tcl interface quite a lot between versions. Worth a go to try the upgrade to 2016.2 but dont expect things to go smoothly. Easiest is to download 2015.2 plus the update. They will install ok so that you can use both at the same time, then build the oh fpga and stick with 2015.2. If you want to upgrade I am guessing that the easiest is to load the created project into 2016.2 and do the update that way. By update of the project you avoid the tcl issues. I would only update if you want a specific feature of 2016.2.
Peter.
PostPosted: Mon Aug 15, 2016 8:48 pm
by peteasa
@jimmystone: looks like the stable branch https://github.com/parallella/oh/tree/stable is the best bet. I created a working project from that just now.
Peter.
PostPosted: Tue Aug 16, 2016 12:09 pm
by jimmystone
peteasa wrote:@jimmystone: looks like the stable branch https://github.com/parallella/oh/tree/stable is the best bet. I created a working project from that just now.
Peter.
Thank you, Peter. I just upgrade to 2016.2 by hacking the version number 2015.2 to 2016.2 and it works fine and vivado generate a new system_bd.tcl for me.
