Introduction to parallel programming with 'foreach'
Moderator: censix
Re: Introduction to parallel programming with 'foreach'
Postby cozymandias » Wed Oct 16, 2013 6:43 pm
Got it, yes, that sounds about right for 4 workers.
cozymandias
Postby tleitch » Sun Sep 14, 2014 4:26 am
I use foreach on a cluster of Macs and utilize the GPU's through nvBlas. When I look at the parallela, it seems there is no benefit since there is no optimized BLAS utilizing the epiphany co-processor. I can see that I could possibly run 2 foreach forks on the parallela because of the main processors dual core. Is this right? Is there any benefit relative to adding another i7 at 2.6 ghz with 4 cores/8 threads?
tleitch
Postby 9600 » Sun Sep 14, 2014 9:44 am
tleitch wrote:Is there any benefit relative to adding another i7 at 2.6 ghz with 4 cores/8 threads?
Power consumption, for one.
Postby tleitch » Sun Sep 14, 2014 10:03 pm
I can afford my electric bill, but my GARCH studies take 42 hours each (if nothing gets messed up) to run on 28 intel cores and I need to run 12 of them, so wondering whether I should keep buying more i7 based Macs or could I get more bang for the buck by building a parallela cluster? Right now, w/o epiphany optimization, my guess is stay with the i7.
tleitch
Postby davewr2015 » Sat Aug 29, 2015 9:24 pm
David.S wrote:This blog post may be interesting to some of you. It's an introduction to parallel computation with the 'foreach'-package.
Looks like going parallel in R can be pretty straightforward once we have epiphany support.
http://www.exegetic.biz/blog/2013/08/the-wonders-of-foreach/
I think this post has moved to :
http://www.r-bloggers.com/the-wonders-of-foreach/
It's worth a look.
davewr2015
Postby sebraa » Tue Sep 01, 2015 12:11 pm
tleitch wrote:whether I should keep buying more i7 based Macs or could I get more bang for the buck by building a parallela cluster?
Well, I guess a i7-based PC is cheaper than an i7-based Mac...
Return to R
