R 3.0.2 on Parallella Ubuntu
PostPosted: Fri Oct 24, 2014 10:18 am
by philipz
I found R have installed on Ubuntu 14.04 for Parallella. But, this R 3.0.2 isn't installed Rcpp and ROpenCL.
I suggest the release image could pre-load those packages.
Re: R 3.0.2 on Parallella Ubuntu
PostPosted: Sun Oct 26, 2014 7:24 pm
by censix
From the R prompt, do
install.packages('Rcpp ')
install.packages('ROpenCL')
and you have what you want. Takes about 5 seconds to install....
PostPosted: Sun Jan 25, 2015 11:35 pm
by sneuf0897
Hi Censix,
censix wrote:From the R prompt, do
I get this when I try to install ROpenCL
package ‘ROpenCL’ is not available (for R version 3.0.2)
What can I do to get past this?
PostPosted: Sun Aug 30, 2015 1:08 am
by davewr2015
sneuf0897 wrote:Hi Censix,
Same Issue! R 3.03
Any solutions?
PostPosted: Wed Sep 23, 2015 3:03 am
by Timtator
I have a solution.
To install the packages, not as root and outside of R. Run these three commands:
sudo su - -c "R -e \"install.packages('Rcpp', repos = 'http://cran.rstudio.com/')\""
sudo su - -c "R -e \"install.packages('logging', repos = 'http://cran.rstudio.com/')\""
sudo su - -c "R -e \"install.packages('ROpenCL', repos = 'http://repos.openanalytics.eu', type = 'source')\""
Then you should have ROpenCL installed :)
However, as Censix has said in another thread, the package needs slight modification.
So instead of running the last command above, you are probably better off doing this:
wget http://repos.openanalytics.eu/src/contrib/ROpenCL_0.1-2.tar.gz
tar zxf ROpenCL_0.1-2.tar.gz
wget http://censix.com/parallella/parallella-ROpenCL_0.1-1.patch
patch -p0 <parallella-ROpenCL_0.1-1.patch
R CMD INSTALL ROpenCL
Then when you type in R:
require(ROpenCL)
You will see:
Loading required package: ROpenCL
Loading required package: Rcpp
Loading required package: logging
coprthr-1.6.0 (Freewill)
Then type in R:
p <- getPlatformIDs()
d <- getDeviceIDs(p[[1]])
d
And you should see both devices as opposed to just the host:
[[1]]
<pointer: 0xcb1010>
[[2]]
<pointer: 0x7e0b90>
PostPosted: Wed Oct 07, 2015 5:09 pm
by Befedo
Hi folks,
I'm trying to follow your instructions to run OpenCL code within R.
My R Version is
R version 3.0.2 (2013-09-25) -- "Frisbee Sailing"
so far what I did was:
but applying the path fails and leads to:
patching file ROpenCL//src/createContext.cpp
patching file ROpenCL//src/Makevars
Hunk #1 FAILED at 1.
1 out of 1 hunk FAILED -- saving rejects to file ROpenCL//src/Makevars.rej
and if we inspect what's been rejected and look into 'Makewars.rej':
--- ROpenCL//src/Makevars       2012-03-01 18:33:41.000000000 +0000
+++ ROpenCL1//src/Makevars      2013-06-13 20:38:37.554603712 +0000
@@ -1,7 +1,9 @@
 ## Use the R_HOME indirection to support installations of multiple R version
-PKG_CPPFLAGS += -I../inst/include/
+## Parallella: make sure the COPRTHR OpenCL implementation by browndeer is used.
+PKG_CPPFLAGS += -I/usr/local/browndeer/include
 PKG_LIBS = `$(R_HOME)/bin/Rscript -e "Rcpp:::LdFlags()"`
-PKG_LIBS += -L/usr/local/cuda/lib64 -L/usr/local/cuda/lib -lOpenCL
+PKG_LIBS += -L/usr/local/browndeer/lib -locl
 ## As an alternative, one can also add this code in a file 'configure'
so i tried to fix this by hand an tried inside R:
> require(ROpenCL)
> d
[[1]]
<pointer: 0x6db218>
so it seems like the Epiphany isn't found.
Does anybody overcome this error and could figure out an solution?
Thanks for your help and best regards,
Befedo
