Parallella Community • View topic - Camera connection
Camera connection
Camera connection
Postby zodane » Thu Nov 13, 2014 7:19 pm
Hello every one,
I need to connect a camera to the FPGA zynq wich port should i use
I dont want to use PORT
Is there a I2C port (ready to use) in the parallella?
Is there any one here that have connect a HD camera
Where can i fond a H.264 compression for a parallella
:geek:
Regards
zodane
Re: Camera connection
Postby 9600 » Thu Nov 13, 2014 10:11 pm
The quickest/easiest solution would obviously be to connect a USB camera, or to stream video to the board from some other source, e.g. as was done some time ago with an Erlang project that used multiple cameras.
http://www.parallella.org/2013/09/10/ex ... th-pixels/
I2C is brought out to the PEC_POWER expansion connector. If you wanted a fast, low latency interface you could implement this in the FPGA, interfacing with the ARM host via AXI and with the physical connection via the PEC_FPGA connector.
Postby zodane » Fri Nov 14, 2014 3:08 pm
thank you
zodane
