Parallella Community • View topic - [SOLVED] Parallella freezes
Postby gordon » Fri Jun 09, 2017 10:50 am
I had written a code for the epihpany device few days ago. It was running fine, but since few hours whenever i run the code,it freezes and a blank screen appears. Is there a problem with my code? Here is the github link...
https://gist.github.com/dhanu-mamidi/1e ... d1112aee51
Please Help!
gordon
Re: Parallella freezes
Postby GreggChandler » Sat Jun 10, 2017 3:57 am
I did not spend too much time reading your code, but noticed that in file e_task1.c, function getmat(), you return a pointer to a variable allocated on the stack within function getmat(). That is not going to be reliable 'C' code. While you could return a pointer to a "static" variable allocated within your function, that is only because "static" variables are not allocated on the stack. With the variable declared "static" all invocations of the function would share a single allocated variable. This is really not so much an issue with the Parallella, but rather an issue with the 'C' programming language.
GreggChandler
Postby olajep » Sun Jun 11, 2017 11:13 am
Since the screen goes blank instead of locking up that leads me to believe that the board does not freeze, but is shutdown to protect itself from overheating.
Does the board get sufficient cooling, do you have a fan?
// Ola
Postby gordon » Mon Jun 12, 2017 4:20 am
gordon
Postby olajep » Tue Jun 20, 2017 4:33 pm
Postby gordon » Wed Jun 21, 2017 4:38 am
I am using a fan and have no problems as of now, thank you :)
gordon
Postby olajep » Wed Jun 21, 2017 6:10 pm
Users browsing this forum: Google [Bot] and 41 guests
