How to getting start OpenCL on 16-core parallella board
Moderator: dar
Postby elysium5290 » Thu Apr 09, 2015 5:29 am
I have some trouble of building opencl environment ,can someone help me?
I list my all steps
step1
I follow this instruction
http://www.parallella.org/create-sdcard/
and I install Ubuntu 14.04 Parallella (Zynq7020) headless image
then I use ssh to connect my parallella board success
step2
I follow this website
https://github.com/parallella/parallell ... /para-para
and install some package
wget www.mr511.de/software/libelf-0.8.13.tar.gz
tar -zxvf libelf-0.8.13.tar.gz
cd libelf-0.8.13
./configure
sudo make install
wget github.com/downloads/libevent/libevent/libevent-2.0.18-stable.tar.gz
tar -zxvf libevent-2.0.18-stable.tar.gz
cd libevent-2.0.18-stable
./configure
sudo make install
wget www.hyperrealm.com/libconfig/libconfig-1.4.8.tar.gz
tar -zxvf libconfig-1.4.8.tar.gz
cd libconfig-1.4.8
./configure
sudo make install
wget http://www.open-mpi.org/software/ompi/v1.8/downloads/openmpi-1.8.1.tar.gz
tar -zxvf openmpi-1.8.1.tar.gz
cd openmpi-1.8.1
./configure --prefix=/usr/local \
            --enable-mpirun-prefix-by-default \
            --enable-static
make all
sudo make install
step3
follow this website
https://github.com/browndeer/coprthr
git clone https://github.com/browndeer/coprthr.git
./configure --enable-epiphany
make
sudo make install
step4
cd /coprthr/examples/hello_opencl
gcc hello_opencl.c -o hello_opencl.x -I/usr/local/browndeer/include -I/home/parallella/coprthr/include/ -L/home/parallella/coprthr/src/libocl -locl
-L/usr/local/browndeer/lib -lcoprthr
./hello_opencl.x
and it will show
coprthr-1.6.1 (Freewill)
I don't know why
and I am not sure whether I need to install ephiphany SDK or not?
and I try to run hello_stdcl
http://imgur.com/tME8Bfz
it seems shutdown
elysium5290
Re: How to getting start OpenCL on 16-core parallella board
Postby nickoppen » Thu Apr 09, 2015 10:37 am
Firstly, thank you for alerting me to the fact that there is a new version of the Brown Deer compiler available. I've been working on 1.6.0.
Second, you have gotten everything installed correctly. The "shutdown" refers to the end of the OpenCL process.
But, are you saying that the whole machine shuts down? After you see the shutdown you should return to the command prompt. Is that the case?
nick
nickoppen
Postby elysium5290 » Thu Apr 09, 2015 1:35 pm
hi, Nick
"shutdown" is means the message of putty , not the machine shutdown, machine is normally.
I think whether I have not installed the epiphany SDK , so my hello_opencl process can not communicate with coprocessor or not
elysium5290
Postby nickoppen » Fri Apr 10, 2015 12:17 am
Everything looks fine to me.
The image comes with eSDK already installed and you have a correctly functioning OpenCL program.
You don't need to do anything more.
nickoppen
Postby elysium5290 » Fri Apr 10, 2015 9:18 am
Hi, Nick
I find this topic
viewtopic.php?f=13&t=2055&p=12182&hilit=getting+started+with+parallel+programming&sid=5b271488b8cd555880dcbc71eb4ebcd5#p12182
Andrew said that I don't need to install any package when I format the SD card by Headless image.
Then I can run the example.
what do you think about it ??
if you agree that , I will re-format my SD card ~~~~~
thank
Eric
elysium5290
Postby nickoppen » Sun Apr 12, 2015 1:11 am
Yes, that is correct.
The headless image that is available on the Getting Started page has both the eSDK and OpenCL installed. The OpenCL is version 1.6.0 which is not the latest but it will work. This is the image that I am using at the moment.
nick
nickoppen
Return to OpenCL
