Harris corner detector and openCL
Moderator: dar
Re: Harris corner detector and openCL
Postby Nader_Jendoubi » Thu Apr 16, 2015 12:25 pm
Do you think that is a memory problem i think the epiphany memory is not enough what do you think??
Nader_Jendoubi
Postby nickoppen » Fri Apr 17, 2015 1:17 am
At this point we have not come anywhere near the epiphany. clcc operates entirely on the ARM host cores.
Get an executable and then figure out if the algorithm works. I assume that you need to pass the routine an image. Find one that is around 20k (i.e. would easily fit onto one core) and run it. That will eliminate any concern about the epiphanies memory getting in the way. Once you have the algorithm working then use bigger and bigger images to test if your partitioning is working.
The only way to operate in the absence of documentation is to solve one problem at a time.
nickoppen
Postby Nader_Jendoubi » Fri Apr 17, 2015 2:30 pm
HI
i'm trying to optimize the sobel application https://github.com/sclukey/parallella-o ... ter/opencl
I think the transmission time between epiphany(kernel) and ARM is too long, when i took the initial sobel program and delete all the instructions and i tried gbb[i] = gaa[i]
the time measured is 0.33 second .
Is there any solution to minimize the transmission time between ARM and epiphany ???
Nader_Jendoubi
Return to OpenCL
Users browsing this forum: MSN [Bot] and 1 guest
