The use of *.o in linker script, + bss
Postby notzed » Thu Aug 22, 2013 1:04 am
Morning,
I setup a combined makefile using different extensions and implicit rules for epiphany code vs host. My current approach is using different extensions such as '.ec' and '.eo', and so on.
Puzzled as to why the section directives were being ignored, i noticed that the linker script hardcodes a pattern '*.o' for the parallella-specific sections. Unless there's a specific reason it does this perhaps it would make sense to use * like the rest of the rules instead. I also noticed there is no shared bss section which is a bit handy to have.
I don't think it's fully general but this is what i came up with:
.code_dram : {*(code_dram) *(.code_dram) } > EXTERNAL_DRAM_0
.shared_dram : {*(shared_dram) *(.shared_dram) } > EXTERNAL_DRAM_1
.bss.shared : {*(.bss.shared) } > EXTERNAL_DRAM_1
(I think i used external_dram_1 for the last because of some linker conflicts with libc, which i found puzzling as i thought that was what the linker was supposed to resolve. i could be mis-remembering however).
Shouldn't it also be .text.shared and .data.shared as well to fit with the existing naming conventions?
