Page 1 of 2
New eSDK 5 Now Released
Posted:
Sat Jul 13, 2013 6:25 pm
by ysapir
Re: New eSDK 5 Now Released
Posted:
Tue Jul 16, 2013 10:19 pm
by ysapir
Posted:
Wed Jul 17, 2013 5:48 am
by ysapir
UPDATE 2:
In order to support the new
E_DMA_MSGMODE control mode on
E_DMA_DWORD transfers, and to properly handle the
e_dma_copy() function, an update of the ZedBoard's SD Card bitstream is required. Please follow these steps:
1. Download one of the following files:
ZedBoard+E16:
ftp://ftp.parallella.org/parallella/sd_ ... rd_E16.binZedBoard+E64:
ftp://ftp.parallella.org/parallella/sd_ ... rd_E64.bin2. Insert the SD card to a reader connected to your PC.
3. Rename the "
BOOT.bin" file on the card to "
BOOT.bin.bak"
4. Copy the downloaded file and rename it to "
BOOT.bin".
5. Eject card, insert at the SD card slot on the ZedBoard and restart the system.
6. Copy the
matmul-xx example from the
esdk/examples and test.
Posted:
Sat Jul 27, 2013 10:13 pm
by eee
I am looking for the eSDK 5 reference manual.
There is a link on your site referencing to this -
But this link is broken (page not found).
Posted:
Wed Jul 31, 2013 7:42 am
by figual
Posted:
Wed Jul 31, 2013 3:17 pm
by ysapir
Just tested this firmware on my Z64 board. Seems to be working great.
Please make sure that:
1. You use the E64 firmware, not the E16's.
2. When removing and inserting the card, you did not displaced the FMC daughtercard.
3. All jumpers are in place, following the table in the Quick Start Guide.
When you power up the board with the new FW, do you get to see the 2 penguins (Tuxes), or does it get stuck before this stage?
Posted:
Wed Jul 31, 2013 3:47 pm
by figual
Posted:
Wed Aug 07, 2013 2:39 pm
by figual
Any idea about how can I investigate what can be happening with the new firmware?
Fran
Posted:
Thu Aug 08, 2013 8:07 pm
by rtrogan
Hi Fran,
I'm sorry to hear that you are having issues with the new firmware.
Could you please boot the system one more time with the old BOOT.BIN and check if /etc/rc.local file is invoking any special script. In particular I'm interested to know if there is a clock divider script in there (lclk_div). If the script exists, please comment it out and try to reboot with a new BOOT.BIN
Thank you,
Roman.
Posted:
Tue Aug 13, 2013 1:54 pm
by Gravis
small request: change the default target in the configure scripts to "epiphany-elf"
i assumed it would be the default and i ended up with my own computer as the target. configure --help didn't give me a list of targets so i didn't really know the target to specify. it took a while before i realized the target was listed in the build script.
