Parallella Community • View topic - ESDK installation problem
Re: ESDK installation problem
Postby Marcio » Thu Jun 27, 2013 9:17 am
Marcio
Postby ysapir » Thu Jun 27, 2013 2:01 pm
Postby theover » Thu Jun 27, 2013 4:45 pm
SO is this guy a backer, or lumberjacking parts together to make a nice IT-type of mess of things ??
Postby Marcio » Fri Jun 28, 2013 3:01 pm
Marcio
Postby Marcio » Fri Jun 28, 2013 4:35 pm
Marcio
Postby ysapir » Fri Jun 28, 2013 9:16 pm
The firmware is (among other things) the FPGA bitstream that is used to tie the Epiphany FMC daughtercard to the Zynq based system. Without a proper bitstream you cannot connect to the Epiphany. We don't provide a bitstream for the ZYNQ board, just the ZedBoard. Possibly, you may be able to make the necessary adaptations to the ZedBoard design to make it work on the ZYNQ board.
Postby anupkini » Thu Aug 15, 2013 1:01 pm
anupkini
Postby ysapir » Thu Aug 15, 2013 2:17 pm
The GNU toolchain is an essential part of the eSDK. It contains the e-gcc compiler, binary utilities, debugger and more. The eSDK adds the other parts, like host and device run-time libraries, BSPs, examples and documentation.
If the GNU toolchain is not found, the SDK build script will halt, asking you to build the toolchain and put it in place before continuation.
Postby anupkini » Fri Aug 16, 2013 10:54 am
anupkini
Postby ysapir » Fri Aug 16, 2013 7:22 pm
