Parallella Community • View topic - Getting started with e-gdb
Postby Gravis » Fri Apr 24, 2015 6:13 pm
Gravis
Re: Getting started with e-gdb
Postby skinner » Fri Jun 05, 2015 7:35 pm
skinner
Postby sebraa » Sat Jun 06, 2015 3:17 pm
On the Epiphany, the very first MB of address space always refers to the current eCore. The start address of 0x0 means "call the first interrupt handler", which is correct.
Postby skinner » Sat Jun 06, 2015 3:39 pm
Thanks for this precision, i mixed up the shared memory and the eCore memory, my bad !
skinner
Postby snim2 » Tue Jun 14, 2016 12:42 am
Did you ever fix this? I have exactly the same problem with the 2015 version of the eSDK.
I think you probably do need to compile your ELF file with -g, but that isn't related to the problem you report here.
Sarah
snim2
