Page 3 of 5
Re: New Parallella SDK release! (Beta testers needed)
Posted:
Thu Nov 13, 2014 9:47 pm
by olajep
Posted:
Fri Nov 14, 2014 12:15 pm
by AndyC
Hi Ola,
Should e-server / e-gdb be working?
I know the first post mentions it is unstable but for me it is extremely unstable, cannot even single step.
Cheers
Andy
Posted:
Fri Nov 14, 2014 12:24 pm
by AndyC
Just had the Parallella hang trying to use e-gdb, power cycle needed to get it back.
Nothing in syslog.
Posted:
Fri Nov 14, 2014 12:30 pm
by AndyC
Also I seem to remember seeing a presentation that showed Eclipse on a remote machine debugging using the multicore debugger, is the Eclipse stuff available anywhere?
Posted:
Fri Nov 14, 2014 1:50 pm
by olajep
Posted:
Fri Nov 14, 2014 1:57 pm
by AndyC
I had e-server and e-gdb running, both on the parallella.
I was testing trying to debug the HelloWorld example.
I had set a break at main which was hit correctly, I then continued.
Then there was a pause of a few seconds and the ssh sessions where lost.
Parallella was unpingable at this point.
Posted:
Fri Nov 14, 2014 11:47 pm
by aolofsson
As stated in the release message the gdb is unfortunately in a broken state. It's a high priority item and will be fixed asap.
Thanks for the help checking the new release!
Posted:
Mon Nov 17, 2014 11:24 am
by greytery
Posted:
Mon Nov 24, 2014 3:01 pm
by jeremybennett
Posted:
Mon Nov 24, 2014 3:13 pm
by AndyC
Hi Jeremy,
Ah thanks for the clarification.
How do you recommend debugging a single core then?
Andy
