Memory existence issue :(
Posted: Tue Sep 23, 2014 4:35 pm
Hey guys,
I have a program running the same SREC file on all 16 cores of my board at the same time and I want to read the data I receive back from them.
In order to do this, I intend for each core to write its data in one of 16 specific memory locations allocated within the shared external memory from code running on the ARM chip.
When I allocate some memory within the shared memory from the ARM chip, I'm unsure how to inform the epiphany core's that the allocated memory exists, its address and its size so I can then write to it?
Is there a function which calls a map of the allocated memory on the board or can I hard core a memory address in?
HELP!
HELP!
