Code::Blocks - Good alternative to eclipse
Re: Code::Blocks - Good alternative to eclipse
Postby fbt » Tue Jan 19, 2016 1:59 pm
Hi Andy,
i'm trying to setup the code:blocks IDE following your procedure, but when i finish it, and i try to compile just the dotproduct source code available on the epiphany-examples/apps/dotproduct subdirectory, i obtain the following error:
-------------- Build: Debug in dotproduct (compiler: GNU GCC Compiler)---------------
gcc -Wall -g -g -I/opt/adapteva/esdk/tools/host/include -c /home/linaro/workspace/dotproduct/main.c -o obj/Debug/main.o
g++ -L/opt/adapteva/esdk/tools/host/lib -o bin/Debug/dotproduct obj/Debug/main.o -le-hal
Output file is bin/Debug/dotproduct with size 13.09 KB
-------------- Build: EDebug in dotproduct (compiler: E_GCC)---------------
e-gcc -g -I/opt/adapteva/esdk/tools/host/include -c /home/linaro/workspace/dotproduct/e_task.c -o .objs/e_task.o
e-g++ -L/opt/adapteva/esdk/tools/host/lib -o bin/Debug/Edotproduct .objs/e_task.o -T /opt/adapteva/esdk/bsps/current/internal.ldf -le-hal -le-lib
/opt/adapteva/esdk.5.13.09.10/tools/e-gnu.armv7l/bin/../lib/gcc/epiphany-elf/4.8.2/../../../../epiphany-elf/bin/ld: skipping incompatible /opt/adapteva/esdk/tools/host/lib/libe-hal.so when searching for -le-hal
/opt/adapteva/esdk.5.13.09.10/tools/e-gnu.armv7l/bin/../lib/gcc/epiphany-elf/4.8.2/../../../../epiphany-elf/bin/ld: cannot find -le-hal
Process terminated with status 1 (0 minute(s), 1 second(s))
1 error(s), 0 warning(s) (0 minute(s), 1 second(s))
could you please help me to find out which is the problem?. THANKS
fbt
Postby AndyC » Tue Jan 19, 2016 2:21 pm
HI,
I'm afraid I haven't got a setup for the parallella anymore I gave up on it so I can't look in detail at this.
The error you are seeing is that the libe-hal library is incompatible for some reason.
Can you paste here the output when you build the dot product example using the makefile from the sdk.
Cheers
Andy
AndyC
Postby fbt » Tue Jan 26, 2016 12:12 pm
Hi Andy,
thwere is no output on the terminal when building files ... but the build.sh script is the following (hope it helps):
#!/bin/bash
set -e
ESDK=${EPIPHANY_HOME}
ELIBS=${ESDK}/tools/host/lib
EINCS=${ESDK}/tools/host/include
ELDF=${ESDK}/bsps/current/internal.ldf
SCRIPT=$(readlink -f "$0")
EXEPATH=$(dirname "$SCRIPT")
cd $EXEPATH
# Create the binaries directory
mkdir -p bin/
CROSS_PREFIX=
case $(uname -p) in
arm*)
# Use native arm compiler (no cross prefix)
CROSS_PREFIX=
# Use cross compiler
CROSS_PREFIX="arm-linux-gnueabihf-"
esac
# Build HOST side application
${CROSS_PREFIX}gcc src/main.c -o bin/main.elf -I ${EINCS} -L ${ELIBS} -le-hal #-le-loader
# Build DEVICE side program
e-gcc -O3 -T ${ELDF} src/e_task.c -o bin/e_task.elf -le-lib -lm -ffast-math
# Convert ebinary to SREC file
e-objcopy --srec-forceS3 --output-target srec bin/e_task.elf bin/e_task.srec
thanks a lot for your help!
best regards
felix
fbt
Postby laideybug » Sat Feb 20, 2016 3:16 pm
Hi fbt,
I've been using Code::Blocks for development on the Parallella and have run into the same "cannot find -le-hal" problem. I was wondering if yourself or anyone else has found a solution for this?
laideybug
Users browsing this forum: No registered users and 70 guests
