e-gdb & e-server - Stepping hangs e-gdb
Postby AndyC » Fri Aug 15, 2014 1:31 pm
Hi Guys,
When using e-gdb connected to an e-server breakpoints are working fine but if I try to step e-gdb hangs.
Should this be working?
Andy
AndyC
Re: e-gdb & e-server - Stepping hangs e-gdb
Postby AndyC » Tue Aug 19, 2014 6:40 am
Anyone?
This makes debugging fairly impossible
AndyC
Postby AndyC » Wed Aug 20, 2014 10:07 am
Seems it was to do with using a newish build and kernel, when back to the versions supplied with the parallella and everything works.
AndyC
