Eclipse - ARM and x86_32
Posted: Wed May 21, 2014 10:22 am
I'm having difficulty getting Eclipse.
I've installed the ARM7 SDK from ftp.parallella.org. The INSTALL file implies that eclipse comes with the SDK (point 6. #test eclipse IDE) but $EPIPHANY_HOME/eclipse is not found.
I've tried to install in using apt-get but I get:
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
eclipse : Depends: eclipse-jdt (>= 3.8.1-4) but it is not going to be installed
Depends: eclipse-pde (>= 3.8.1-4) but it is not installable
E: Unable to correct problems, you have held broken packages.
I've gotten cross compilation working for the pi and so I thought I'd give that a try but on the in ftp.parallella.org/esdk/old I see:
esdk.4.13.01.04_linux_armv7l.tgz 134 MB 1/8/13 12:00:00 AM
esdk.4.13.03.30_linux_armv7l.tgz 135 MB 4/2/13 12:00:00 AM
esdk.4.13.04.24_linux_x86_64_armv7l.tgz 458 MB 4/24/13 12:00:00 AM
esdk.5.13.07.10_linux_armv7l.tgz 118 MB 7/12/13 12:00:00 AM
esdk.5.13.07.10_linux_x86_64_armv7l.tgz 422 MB 7/12/13 12:00:00 AM
Which seem to be either ARM7 or x86_64 versions. My Linux is running on 32 bit x86.
Am I missing something?
Any assistance would be much appreciated.
nick
nick
