Interconnected Parallella boards
Postby claudio4parallella » Sat Aug 19, 2017 3:39 pm
Hi all, thank you in advance for contributes.
I've ordered my second Parallella, one Porcupine in order to set up a two-boards cluster and on the other side to make something with gpio.
I've also understood that Parallella boards can be interconnected using Porcupine and PecNorth South connections or something similar. The advantage shoul be, if well understood, a Single System Image as the linked boards are one system.
I'll do my studies and experiments and in the meantime I'd like to understand if any tutorial or specification is available in order to buil up and work with interconnected Boards.
I have red some topics talking about modifications of fpga or something similar.
Thanks for your suggestion to go deeple into experiments.
Cables similar to: https://groundelectronics.com/products/ ... cable-pair
Links to topics:
http://www.parallella.org/forums/viewto ... 885#p18812
viewtopic.php?f=23&t=3659
viewtopic.php?f=23&t=3207&hilit=jumper&start=10
thank you
claudio4parallella
Re: Interconnected Parallella boards
Postby claudio4parallella » Thu Aug 31, 2017 7:20 pm
claudio4parallella
