Parallella Community • View topic - Parallella wireless?
Postby Lou_Reed » Tue Mar 10, 2015 5:08 pm
I have my Parallella connected to the internet via the RS0232 connecti0on and associated cables.
That is awkward to have cable snaking all through the house. I would rather go wireless, like I do for my laptops.
is this possible for the Parallella?
I have a powered USB hub with open USB connections.
I could use a USB Wi Fi. I have seen this work on laptops so maybe on a Parallella?
Any help appreciated.
Thanks in advance.
Respectfully,
Lou_Reed
Lou_Reed
Re: Parallella wireless?
Postby 9600 » Tue Mar 10, 2015 8:01 pm
Yes, using a USB wireless adapter is possible. , but I see that there are RTL adapters in the now, so if you're using a recent kernel there may already be support.
Postby Lou_Reed » Wed Mar 11, 2015 12:55 pm
How can we tell without actually buying a USB-Wi Fi if the software is already integrated into our Ubuntu kernel?
Thanks in advance.
Respectfully,
Lou_Reed
Lou_Reed
Postby 9600 » Wed Mar 11, 2015 1:26 pm
The second link in my previous post was to the default configuration file which is used when building the Parallella kernel. This lists all the modules/drivers that will be integrated.
Postby manklee » Wed Mar 11, 2015 10:59 pm
I plugged something like this:
http://www.amazon.com/Edimax-EW-7811Un- ... sb+adapter
into my powered USB hub, made some easy changes in "Preferences, Network connections" and was online. The above links to a different wireless usb adapter than the one I used. I can't find the exact model of my Edimax wireless usb adapter.
manklee
Postby 9600 » Thu Mar 12, 2015 8:14 am
Appears that Edimax model is based on a RealTek device. Perhaps you could add it to the page?
Note that you sometimes have to do a little bit of research to find out which particular chip a WiFi or LAN etc. adapter actually uses.
Postby manklee » Fri Mar 13, 2015 9:27 pm
I added the device to the peripherals page.
manklee
