Case Design Files?
Case Design Files?
Postby anlumo » Tue May 06, 2014 10:15 pm
Are the vector files for the official case available somewhere? I'd like to replace the top with a plate that can mount a fan, and it'd be easier to do if I wouldn't have to measure the little slots and the outline…
anlumo
Re: Case Design Files?
Postby gceline » Wed May 07, 2014 2:35 pm
No - this was made by a third party
Graham
Adapteva
gceline
Postby 9600 » Wed May 07, 2014 4:06 pm
If you have access to a laser cutter and were prepared to source a few more parts you could make a new "open case" based on the design I've published.
Postby anlumo » Wed May 07, 2014 5:13 pm
I saw your case, but I don't like its (physical) openness. It's too easy that something gets in there when I'm carrying it in my bag…
anlumo
Postby anlumo » Wed Jun 04, 2014 3:34 pm
In case (no pun intended) anybody is interested, here's the OpenSCAD code for the top plate (1 unit = 1mm):
difference() {
   cube([98.5, 76, 3], true);
   for(i=[-1, 1]) {
      for(j=[-1,1]) {
         translate([i*(77.4+2.4)/2, j*(46.5+6.3)/2, 0])
            cube([2.4, 6.3, 5], true);
         translate([i*(73.2+15)/2, j*(70+5)/2, 0])
            cube([15, 5, 5], true);
      translate([0, i*(70+5)/2, 0])
         cube([48, 5, 5], true);
anlumo
Postby 9600 » Thu Jun 05, 2014 6:58 am
anlumo wrote:In case (no pun intended)
Not intended, but appreciated all the same :D
(and thanks for the code!)
Postby anlumo » Fri Jun 06, 2014 2:33 am
Here's the end result:
anlumo
Postby Gravis » Mon Jun 09, 2014 12:24 pm
anlumo wrote:In case (no pun intended) anybody is interested, here's the OpenSCAD code for the top plate (1 unit = 1mm):
awesome! i had never heard of OpenSCAD and i've been looking for an easy to use CAD program. code is a great interface! :D
Gravis
