Parallella Community • View topic - is there serial access
Re: is there serial access
Postby timpart » Thu Jan 23, 2014 2:02 pm
Postby TrikingSheep » Thu Jan 23, 2014 2:22 pm
I think Andrew's idea was to connect the RPi's data port to a 4 way or 8 way switch matrix and use the RPi's GPIO buss to switch the switch.
This could be done all with logic chips.
To switch 4 ways would need 2 GPIO lines and 8 way would need 3 GPIO lines.
Using standard GPIO lines as UARTS is possible, but you would need to write the "bit banging" and UART code to be able to do this, something I had to do for my VHDL course I did when doing my MSc.
Kind Regards,
Julian.
TrikingSheep
Postby timpart » Thu Jan 23, 2014 5:36 pm
Postby mhonman » Thu Jan 23, 2014 6:34 pm
A quick way of getting a couple of extra UARTs would be something like an ARM microcontroller board (e.g. the microcontrollers on ST's "discovery" boards have 3 or 4 UARTs).
But most likely the easiest way is to have multiple USB RSR232 converters on a hub connected to the RPi or other master machine. In that case I'd be tempted to go for a Vista licensed ultra SFF PC (e.g. Lenovo M58p) which having a gigabit NIC could also be a storage server for the cluster. And for that matter it'd probably be able to supply enough 5V for 8x Parallella boards, into the bargain.
mhonman
Postby TrikingSheep » Thu Jan 23, 2014 6:41 pm
The down side of using USB / RS232 converters is that they output RS232 levels +/- 12V.
The Parallella's only use LVTTL levels of 0V to 3.3V.
For the USB / RS232 converters to work there would have to be MAX3232, or similar, converter ICs at each Parallella to convert back to LVTTL.
Kind Regards,
Julian.
TrikingSheep
Postby TrikingSheep » Thu Jan 23, 2014 6:43 pm
TrikingSheep
Postby mhonman » Thu Jan 23, 2014 8:07 pm
mhonman
Postby TrikingSheep » Fri Jan 24, 2014 8:27 am
TrikingSheep
Postby 9600 » Fri Jan 24, 2014 8:52 am
Postby shodruk » Fri Jan 24, 2014 11:26 am
Thanks everyone!
I'll be careful not to connect to the wrong pins. :)
Users browsing this forum: No registered users and 44 guests
